xcopy and harddrive cloning
Help !!!
I have installted all new drive and seem to remeber something about xcopy and the H switch however what version of xcopy has this as my one just says it dosent have an H switch
or can anyone tell a free piece of software I can use the drives are from 2 different manufactors and they are also not mainstream so no software availble from them
Thx in advance
J
It isnt free but I use Norton Ghost for this sort of thing.
It does lots of other things as well as just cloning Hard Drives.
I have found it to be worth the initial outlay over the time I've been using it.
I would recomend Norton Ghost too.
Allthough it can be complex to understand at first, the wizard takes you through most of the steps in windows, prior to rebooting and performing the ghost operation.
Harddrive swap times where tested yesterday for myself. Out of the 1 1/2 hours spent working, only 20 mins was doing the copy. The rest was testing the system for problems and clearing the dust off the guts.
The writers of http://www.xxcopy.com now have a beta version of http://www.xxclone.com available. This may be what you want.
I have just used Acronis TrueImage to back up my hard disk. It was very efficient. Other people use Norton Ghost with which I am unfamiliar.
You could also try PartitionMagic, you can use that to copy partitions too
xxcopy
Thats the ticket xxcopy worked the way xcopy is supposed to anyway thax for all your help !! I do use ghost etc but just didnt have the time nor the discs handy to perform the required and as usual Microsofts kit just wasent upto the job !!
Cheers
J
