windows media player
im having trouble opening video files
i receive an error C00D1199: Cannot play the file
these files were working perfectly fine before
but know they have stopped working on windows media player and windows movie maker
i used to be able to edit these files but know i cant
the files have lame mp3 audio format and there is divx video compression
any suggestions appreciated
1 REPLY
Here is what the error means and how it can be fixed:
http://www.updatexp.com/c00d1199.html
If you cant find the solution there, try installing K-Lite Codec Pack:
http://codecpack.nl/klcodec272f.exe
It contains most of the codecs used in video/audio footage.
