which is the best amd cpu for playing games 4600x2 or 4000+
i need a new cpu i have amd 3500 i am looking at a amd athlon 64 4000+ or amd athlon 64 x2 4600 whitch one will be the best got £180.00 to spend
someone told me to get the amd 4200x2 is a better cpu
is the 4600 a manchester coreHuhHuhHuhHuh
ps the price have shoot down to 176.12 for a 4600x2
140.45 for a 4000+
will the 4600 x2 run on xp home Huh
Firstly, conroe would be better than any AMD now, and what do you mean "will the 4600 x2 run on xp home" Huh
The_10th
I would think the 3500+ is a pretty good CPU and wouldn't upgrade just yet, but if you did then you can get a 4200+ for £125 or 4600 for £160. Just google them to see what is best esp regarding overclocking if that is your 'thing' so to speak.
BTW you have already asked this question on post further down the page (double post).
Buzzons he wants to know if the Dual Core Processor will work with both Cores on Windows XP Home - The anwser is yes it will.
Personally I wouldnt advise you upgrade, if you do want to upgrade now - go for a Dual Core Processor. If you can wait to upgrade - build around the new Intel Core Duo 2 as Buzzons mentioned. Code-Named Conroe.
The_10th
Going for Conroe depends on whether it is financially beneficial as would need a £100+ mobo plus DDR2 RAM whereas an AMD 'X2' would be likely to work without any extra hardware and performance is still very good.
conroe takes DDR ram as well doesnt it? if not, its time to upgrade anyway :p
