what is it
subsailor
what is it
On start up the following is displayed. C:\progra~1\Symantic\s32vnt1.dll
Tells me it cannot load. Please how to elimnate/restore.Not to complicated as I am a newbie.
Jan :?:
Mike_Grice
Re: what is it
Jan :?:
Off the top of my head I would say that it's a left over file from Norton Antivirus - if you reinstall it you should be fine...
what is it
go to Run and type 'msconfig' and press enter. check the Startup tab and look for that program. untick the box relating to it and reboot. that might fix it Smiley
what is it
This is a DLL file, which can't be loaded via this system (though rundll will, but doubtful that it's used).
It sounds like curruption of the file, or accidental deletion has caused this.
The re-install method would be wise.
If you have removed the program receintly, then you have done it incorrectly, you will need to re-install the software, then use the correct uninstall method.
subsailor
what is it
Thankyou for all your help. A reinstall of the norton fixed the problem. Cheesy
Jan
