virus paranoia
virus paranoia
I'm looking for help to solve the following two issues on a well used Windows 98SE hard drive that I am cleaning up to use as a backup pc. I don't know if the two problems are related as they are a bit above me.
First, when booting up, the following line appears after the c prompt:
C:\>SET BLASTER A220 I2 D1 T4
The word 'blaster' set me reaching for the antivirus. I have done scans from inside Windows with McAfee and a Symantec Blaster removal tool and also from DOS with McAfee on a bootable utility cd and all show it is clear. Can anyone set my mind at rest and explain this line?
I should mention that I have Hyperos loaded on the drive, but I'm pretty certain that this is not responsible.
Secondy, I cannot use Scandisk or Defragment from inside windows as they throw up a message that a programme is running and keeps stopping the process. The ' programme ' that is running appears to be the following:
C:\WINDOWS\RUNDLL32.EXEshell32.dll,SHExitWindowsEx1
A message saying that this is running appears when shutting down. It was in the startup menu and I removed it, but it seems to still be active in the background.
Very grateful for any help. Thanks.
Re: virus paranoia
This is for a sound card, a sound blaster card Cheesy
You need to deframentation with no other programs running.
virus paranoia
Thanks for the reply about the soundcard.
The second problem still occurs when I've shut down every thing that I can find that is running. Can't seem to stop it.
virus paranoia
Start windows in safe mode, then run scandisk and disk fragmenter
