video transfer
morgan2476
video transfer
Is it possible to transfer videos from my camcorder to my PC?
1 REPLY
video transfer
Short answer: Yes
Long answer: How you go about transfering video from camcorder to PC depends on what kind of outputs your camcorder provides.
Most traditional camcorders only have RGB/Composite out which is used to connect to a TV/VCR, however there are add-on cards for the PC which will accept the same connections, and they usually come with the software to make the transfer.
It probably would be cheaper to buy a TV tuner card with VCR/Other in than a professional card, but if you don't already have a TV licence, you'll need one with such a card.
I've not used a TV card for over 7 years so I don't know whats hot and whats not, but some cards can be found here
If you have a digital camcorder it may have a FireWire port on it for high speed transfers and no additional software should be needed.
HTH.
