user id
slanjavah
user id
How can I stop windows xp pro asking me to click on user each time it loads or comes out of sleep mode. My pc does not have multi users so no need for this extra security
ta
may the force be with you
worm
user id
Not sure if you can do it the easy way (through Control Panel etc.)
but this KB article tells you what to do
http://support.microsoft.com/kb/315231/en-us?FR=1&PA=1&SD=HSCH
user id
it may just be as simple as unticking the box under the screensaver options that says ask for password after screensaver etc
user id
Or....
Click Start, Run and type CONTROL USERPASSWORDS2, and click Ok. Select the user account from the list (to which account you want to automatically logon). Uncheck Users must enter a user name and password to use this computer option, and click Ok. Type the user account password and complete the process.
For Windows XP Home, don't try to auto-login as the built-in Administrator, as you'll receive a restrictions error.
slanjavah
user id
Thanks for that.
and sadly I can't get 2mb either
May the force be with you
