usb hard drive
usb hard drive
have a usb hard drive 2.0
connect it up
doesnt work
green light is on
cant access hard drive
i think its a power problem
only using 1 usb device which is mouse
cn u help me?
usb hard drive
What version of USB does the drive require - USB 1 or USB 2?
What version of USB does your PC support and what version socket are you using?
What Windows version are you using?
A silly Q I know but have you read and followed the installation instructions properly and if drivers are required that you connected the USB drive when the instructions indicated. Some drivers will not install properly if the device is plugged in at the time or at the wrong time.
usb hard drive
my computer is usb2 hard drive is usb 2
i have win xp
sumties drive will appaear and then dissapear
usb hard drive
Is this a power problem, is your PSU "big" enough? Cheesy
usb hard drive
Its an external drive so it takes power from its own connector, I would assume the USB cable or port is either damaged or dirty. try cleaning them or using a diff cord to check.
buz
usb hard drive
hard drive defintly works its brand new only bin used a few times
i really doubt that my psu isnt large enough?
but its defintly a power problem yh
