ups
ups
Can anyone give advice concerning a ups. I am just looking for something basic, something just to keep my P.C. alive during a short term power loss.I think my power supply is 350w. Would that affect the amount of VA that they output :?: Smiley
ups
We would tend to favour APC UPS.
For a product configurator for your needs see here
ups
Thanks for the link. I was thinking more on the line of more basic than that. My problem was that I had momentary power cut that caused my pc to shut down. at the time I was downloading and because it wasn't shut down properly I lost all that I had downloaded. I'm really just looking for something to tide me over that. Something in the region of £100
ups
APC BACK-UPS HS 500VA 230V
Price: £79.99
NEW! APC Smart-UPS SC 620VA 230V
Price: £129.99
A search on Google will reveal better pricing.
Not sure what you looked at in the link?
holdtight
ups
Recommend APC i use one it was cheap enough at £69 and i get 10 mins to shut down if there is a powercut plus the obvious surge protection
i dont understand what you mean by more basic it doesnt really get more basic than that
ups
It was the configuration page on the link that did me. I ticked all the boxes, processor, hard drives etc,and it came up with items costing £250-£300. Could anyone say whether these backups come with software to shut down any programs that are running when the power goes.
ups
Ah. Think i see what happened there. Did you select the external devices?
Most of the APC Smart UPS come with Powershute s/w which is quite good though I didnt see that mentioned on the APC site.
Check for that info from the retailer you decide to go with. I have always found it bundled in the box.
ups
Dunno if you got the info you needed re. shutdown. APC have a Powerchute program which controls graceful shutdown of programs in the event of power loss, this can be set to trigger after say 3 minutes of loss so as to not begin the process over short term glitches in supply and works well. Whether it is bundled with the lower priced/spec UPS I have no idea as I use a 1400 but it is downloadable from the site. Look at Liebert as an alternative and suppliers Staples, Maplin and if you can stomach poor advice, PC World.
ups
Thanks for all your help. All I have to do now is make a decision :roll:
ups
P.S,
Just checked and yes, both UPS mentioned come with software included.
