uninstall fodlers
uninstall fodlers
In my C:/windows directory i have loads of folders similar to $NtUninstallQ817606$
Can i delete all these folders?
1 REPLY
Njal
uninstall fodlers
"When you install updates from Windows Update, backup folders are created for the files that were replaced during the update. These are created so that you can easily uninstall a particular Hotfix, if it causes problems with your system. If your system is running stable and you don't need to uninstall the hotfixes, then you can safely remove the backup files to free up disk space."
http://www.dougknox.com/xp/utils/xp_hotfix_backup.htm
Regards
Neil
