tv tuner driver
tv tuner driver
Hi was wondering if anyone has any ideas
Have just formatted my comp and i cant get my media centre to work when opened it tv tuner not installed
Am not very good at these things so be gentle with me lol
p_w_d_stone
tv tuner driver
Go to the manufacturers website, download and install the relevant drivers for the TV tuner. If it's a newer laptop and the TV tuner came with it then the drivers should be on the laptop manufacturers website (e.g. HP) if it's something you purchased seperately then you'll need to go to the manufacturer of the card.
If you're not sure then it migh be an idea to run Windows Update as this may be able to locate the driver for you.
tv tuner driver
Hi thanks for the reply tried the update did not work will try manufacturer for my comp :lol:
