thx
thx
yes thx, but iv tried that and it wont have it ,.ta
Basically we are having truoble running the sims 2 game, wont load up get error message " failure to initialise direct3d " . it worked fine untill xp WAS INSTALLED. WE HAVE ALL THE LATEST DRIVERS AND everything but this is just buggin us. hence i thught if we can get ME on another drive then try it trial and error basically . thx
thx
Make sure your graphics card drivers are up to date, Make sure your graphics card is compatible, Make sure your using the latest version of DirectX (DirectX 9.0c) (Start / Run "dxdiag")
thx
You could try compatibility mode.
Simply right-click on the Sims 2 icon on your desktop (or wherever you launch the game from) and select "Properties" then click the "Compatibility" Tab and select:
"Run this program in compatibility mode for:"
Then navigate the drop down box to:
"Windows 98 / Windows Me"
If it still doesnt work try and do a Microsoft Windows Update.
http://windowsupdate.microsoft.com/
