thunderbird
thunderbird
I dont seem to be able to send email using thunderbird. Does anyone have any experience of this? will it work with plus net? if so what do i need tyo do?
Peter
[Moderator's note (by Chris P.): Removed unnecessary BBCode tags for you]
thunderbird
What have you set for the SMTP server?
Do you get any error messages?
painswck
thunderbird
Hi Peter (squirecorps),
Yes Thinderbird does work with PlusNet. I use it sometimes.
I assume you have set up an 'account'.
Have you set up the correct SMTP server. Undet tools -- Account Settings -- Outgoing Server (SMTP) make sure that Server Name is set to relay.plus.net and port should be 25. Use Name and Password should not be ticked and Use Secure Connection should be set to No.
Trust that is of some help.
Roland
thunderbird
thanks for the help above now sorted
painswck
thunderbird
Glad you got it sorted.
Roland
fc9k
thunderbird
just popping my head in to say thanks very much for this, i searched the forums thinking someone may have had this problem aswell as me Smiley thunderbird was trying to log into the smtp server.
thunderbird
Thanks for this thread, just spent days trying to sort this and tech support didn't know the answer, so ill check the forums first next time Smiley
thunderbird
Go to
Tools
Accounts
Outgoing Server
UNCHECK the box Username and Password.
These are NOT needed to send emails via Thunderbird..
