temperature xfx 7900gt
just got this card can anyone tell me the temperature for this card and the core slow down threshold mine stays at core temp 45c running games it goes up to 50c what is the best core slow down to set it at or is ok... Shockedops:
The threshold? Leave it as it is bud.
Also your temps are fine, these 7900's run realy cool!!
Thats spot on rtparry, I have exactly the same temperatures on my 7900GT.
Under heavy load it will only go to about 50-60c which is still considered a very low temperature for a graphics card because their thresholds are so high.
nVidia set the default threshold to 125c and I have never heard of anyone changing it or any reason too change it.
So yeah, dont worry Wink
7900gt
thanks again u two u are always the first to reply to help people keep up the good work................
