system 32
westie
system 32
novice windows start up ok followed by desktop icons and then system 32 full page these files are hidden have to close each time to continue a pain how do i sort it Sad
system 32
how is it displayed in a explorer window or other. You will be looking at something running in your startup or you have it saved on your desktop. It can often be just a . that is the problem if you goto start run then put in a . and press return files will come up so a extra . in a startup can cause it. Run msconfig and see if you can spot anything in there
westie
system 32
thanks for help mwright will try your advice
