spyware
spyware
every time i scan for spyware using spyware doctor, towards the end of the scan the computer automatically restarts
im using the latest version which is something like 3.2.1.359
Midville
spyware
Have you tried using different programs, MS and Ad-adware?
arlehaven
spyware
It sounds like your spyware doctor has become corrupted or it has found spyware that it cannot treat. As midville has suggested try using a different anti spyware programe.
Microsofts Antispyware although in it's beta stage is proving to be an excellent piece of software.
Download link: Here
Make sure your antivirus programe is upto date and run a full scan.
spyware
Other spyware links:
Adaware: http://www.lavasoftusa.com/
Spybot: http://www.safer-networking.org/
spywareblaster: http://www.wilderssecurity.net/spywareblaster.html
Microsoft AntiSpyware http://www.microsoft.com/athome/security/spyware/software/default.mspx
I don't use the last one personally but it comes recommended.
The best protection against spyware is to not use internet explorer or if thats not an option, set your ActiveX to strict.
Regards,
Andrew D Wiles
