sound blaster audigy se
can anyone tell me if i can use my two speakers and a headset on this card i have tryed for 1 hour to set this up play games on line and use skype in the game no sond throw headset
or if i got a new headset with usb will that work
1 REPLY
Fixes: 57
Assuming its the same as my Audigy 2 you can have either headphones or stereo speakers but not both at the same time as they both use the same port. Are you trying to put the headphones into the digital output port. This will only work with digital headphones
