screen saver
subsailor
screen saver
I am running 2K. Not sure of the all the other bits.
Monitor shut down.
Display properties, power options. Turn off monitor after say 15 mins.
works OK during the using time. When I shutdown I have to reset the time
for monitor shutdown . This applies to any time selected. The monitor s/d will not carry on to the start up. If a sloution is available please not to complicated.
edjan
screen saver
TO my understanding, you have to save the new values in a power scheme, which can be done on the same screen.
screen saver
The problem with this is which takes control. Normaly you can set power options in the bios as well as in the control panel and one over rides the other. The bios should over ride the o/s by rights.
Set you power on in the bios and set the monitor etc there if you can. If you are setting it in control panel make sure you have admin rights.
Dos games and dos prog tend to confuse the issue as well
