rundll32.exe
zpeterk
rundll32.exe
rundll32.exe is using 99% of cpu usage, anti virus xp up to date etc, help?
zpeterk
rundll32.exe
just noticed in explorer if you click on c it says
These files are hiden
This folder contains files that keep your system working properly. You should not modify its contents
zpeterk
rundll32.exe
And not suprisingly also zone alarm and norton have turned them selfs off
rundll32.exe
rundll32.exe is used to start other apps. It looks like it has got stuck or you have been infected so just kill it or reboot.
After a reboot do a full system scan. I also suggest you run spyware and trojan scanners as virus scanners don't pick up that type of infection. See the security software tutorial for links to online scanners and others you can download.
zpeterk
rundll32.exe
I found it
newdotnet.dll
Thanks Peter
rundll32.exe
Info and removal instructions can be found here: http://cexx.org/newnet.htm and http://cexx.org/newnetfix.htm
Note: just removing the dll can sometimes cause issues with some running programs - the above links give the correct removal info. It can also effects/reconfigures winsock so correct removal is important. If you get an error on reboot saying the dll cannot be found/loaded, it as not been removed properly
I assume it was found by a spyware scan, if so that tool should have removed it properly but I would check the above links just in case.
