resizing parition
resizing parition
i'd like to resize my c drive(active drive, operating system drive , windows xp)
is there any way i can increase the size without losing any data and safely, i have plenty of gigabytes of hard drive space, i made a mistake by only assigning 5GB to the c drive and know i have a few problems here and there,
any suggestions are most welcome
thanx
naeem
madswitcher
resizing parition
One way is to use a drive imaging utility like True Image which allows you to restore an image back of a different partition size. Alternatively, something like Partition Magic?
Whatever you do, i suggest that you use a drive image utility to make a back up to another drive first.
Good luck, Mike
resizing parition
you can do it from drive tools in the admin area on windows i think as well -- but that kinda sucks
resizing parition
You can get s free partitioning software from
http://visopsys.org/partlogic/download.html
lingbob
resizing parition
Either Partition Magic or Bootit NG will do what you want.
Regards,
Martin
morgan2476
resizing parition
Partition Magic is definately the best but you can try Partition Commander
resizing parition
i did it with paragon partition manger 2005
did the job
resizing parition
You can also use ntfsresize : http://linux-ntfs.sourceforge.net/man/ntfsresize.html
It is found in any Linux distrib but you don't need Linux to use it. I resized a Windows XP partition with it. I made it smaller, but it can also expand a partition. Good news : it is free, unlike Partition Magic (http://www.symantec.com/home_homeoffice/products/system_performance/pm80/index.html), or Partition Manager (http://www.7tools.com/pm/index.htm). However Partition Logic is also free, but I have not used it.
Do a backup of the most important files first.
