raid or sata2 how do i set it up
i have a raid ulitily on start up ali i have a asrockdeul-sata2 m/b when installing this drive i did what windows said and make a floppy disk for my hard drive which is a wd1600js 8mb 300psp 160gb sata2 in the bios i make it a none raid because i have only 1 drive is that right
ps can i uninstall the raid manager when starting the pcHuh
p ps::::::: it show in the uiltly at 150 speed it should be 300
indeed you can not have RAID due to the fact you have only one disk.
no you can not remove the RAID utility as its firmware on a chip -- removing it will probably break the chip in such a way you can not even see your hard disks.
I cant say why its seeing the disk as SATA not SATA2 but it doesnt really matter -- there will be no situation where you are writing at more than 100mb/s (so no where near 300mb/s) -- yet the disk will still do SATA2 speeds even if the bios thinks its SATA (you may need a bios flash)
Raid 0
Actually Raid 0 is one disk (bit picky I know)
no, its not.. Raid0 news TWO disk
RAID 0
A RAID 0 (also known as a striped set) splits data evenly across two or more disks with no parity information for redundancy. It is important to note that RAID 0 was not one of the original RAID levels, and is not redundant. RAID 0 is normally used to increase performance, although it can also be used as a way to create a small number of large virtual disks out of a large number of small physical ones.
so what can we learn from this, RAID0 is over two or more disks
A very useful (pretty pictures etc) guide to RAID can be found here...
http://www.acnc.com/raid.html.
Though it doesn't list all the non-standard modes it does a good job with the all standard modes...
OOPs
Sorry,
You are quite right raid ) is stripped
My Error
Ned to engage brain before turning on typing fingers
Cheesy
Opps again
That should have read raid 0 not raid )
Brain still not engaged
Nope, its the shift key which you need to disengage rather than engaging the brain Wink
