"Unknown Network Sharing device found" ?
Stef
I wonder if anyone can help?
A colleague of mine has just signed up with PN and is trying to configure his DG834G. He is running XP (Home or Pro I am not sure?) and got a friend to install a NIC in his machine + drivers.
I have checked the following:-
Modem sync light green on DG834G
Cable connected from PC/NIC to DG834G
Green light on NIC
Firewall off
Tracert 192.168.0.1 works fine
ipconfig shows 192.168.0.2
(I did not try ipconfig/refresh)
Now the problem is with IE (The chap never used IE before because he was an AOL dial-up customer)
When 192.168.0.1 is typed in to IE he IMMEDIATLY gets "The page cannot be displayed..." If Refersh is pressed he sometimes gets "Limited or No Network connectivity - Local Area connction 3" (!), "Didn't assign a network address" "Internet Gateway" "Connection Disabled" or similar - Repair is offered by does not fix it...
(This is all with Auto detect LAN settings switched on) and AOL DUN removed.
If I try the Network Setup wizzard it strangley detects something called "Unknown network sharing device" and configures the network with this even though I select "This PC uses a home/router gateway device" instead...
Suffice to say he called PN CS who kind of shrugged - Actually he said that the PN CS operative sounded rather stressed...
Any ideas or suggestions as to what to try next?
Many thanks, Stefan
Open Internet Explorer
Click tools - internet options check the connection tab and ensure he has no modem/proxy servers set up (click the lan settings button for this (tick the auto detect settings box))
This will ensure his net is not trying to access other modems/routers etc
When you do an ipconfig /all what does default gateway say?
Ill assume you made sure the nic installed ok
Stef
Thanks for this...
I will try it out...
Stef
Re: Open Internet Explorer
Thanks - This SOLVED IT !
Plusnet/Broadband working just fine now!
Thanks again, Stefan
Cheesy
