program display
subsailor
program display
Have had to format back to original W2K disk. Have lost a lot of my tweaks. Can
anybody please help with how to reduce program display to often used programs.
IE start/programs . It then displays the most frequent used ones. Unfortunetly XP suggesting will not work.
edjan :?:
program display
I guess you mean personalised menus.
Right click taskbar, select properties and there should be a tick box to enable/disable personalised start menus.
subsailor
program display
Thank you for the answer aqsk 42. That is what I have done. With no change.
I have had my doubts if that part was working. You have confirmed that I was doing the right thing.
TKS.
