probs with sound card!!!
Currently have C-Media AC97 and tried my old creative labs CT4810 sound card. Run the drivers for both but still no sound! error message comes up with faulty or corrupted driver. I'm not that technically minded but can anybody spare there time to give me some suggestions. PLEASE.
Do you mean you have 2 sound cards installed?
What O/s are you using and have you got the latest drivers?
Does it give any errors in Device Manager?
Are you sure the speakers work ok?
Do you have any other sound device like a modem as often the sound defaults to that instead of the sound card
If your C-Media card is built onto the motherboard and arnt using it try disbling it via a bios change therefore forcing your system to use the creative card. Good point about the modem device definatly check if you have a dial up modem installed as most of them have there own Wave device (Wave device is the output for most sounds made by your computer).
