problem setting up router
Have just received a cisco 857 router
using the following settings
IP address = IP Negotiated ( don't have a static ip address)
VPI = 0 , VCI=38
Operating Mode = ansi-dmt
encapulation = PPPOA (AAL5MUX)
WAN is showing as connected however receving error message below
http://www.sgrazier.plus.com/1.bmp
http://www.sgrazier.plus.com/2.bmp
Please help
Cheers Steve
[Mods note by csogilvie: Images changed to be URLs since the first one was > 1.5MB]
csogilvie
Firstly, as per my note, I've changed the embedded eimages to be links as they were > 2.5MB in total!
My first guess would be that you have ADSL Sync but haven't managed to authenticate to PlusNet, or have it configured to not use the IP obtained when connecting, but I know nothing about Cisco equipment.
psk10
Don,t they have a helpline number ? I purchased a Linksysy Router and wireless card and i had a couple of set-up questions i call the 0800 number and they were very helpful .Linksys is part of Cisco.
log into the router via telnet/ssh/over a consol cable
and do a
show running config
and paste it out here.
NB : you have to do
enable
first, before doing the show command.
re
here's the running config
Sorry plusnet for the image sizes did not realise the size!
Building configuration...
Current configuration : 3387 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret [REMOVED FOR SECURITY REASONS]
username [REMOVED FOR SECURITY REASONS] secret [REMOVED FOR SECURITY REASONS]
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 212.159.13.49 212.159.13.50
default-router 10.10.10.1
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name yourdomain.com
ip name-server 212.159.13.49
ip name-server 212.159.13.50
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode ansi-dmt
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 0/30
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname sgrazier@plusdsl.net
ppp chap password [REMOVED FOR SECURITY REASONS]
ppp pap sent-username sgrazier@plusdsl.net password [REMOVED FOR SECURITY REASONS]
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
cheers Steve
firstly, edit your post to remove your passwords Wink
secondly, edit your config to read as
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
pvc 0/38
dsl operating-mode auto
hold-queue 224 in
interface Dialer1
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap password 7 ur_pass_hash
ppp pap sent-username sgrazier@plusdsl.net password 7 your_pass_hash
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
re
config is now set
assigns ip address (yipee / thanks)
However receive error regarding no exit interface ?
error = www.sgrazier.plus.com/3.bmp
Any ideas
Cheers Steve
odd as you have set the DNS servers up correctly, ill look at it 2moz when i dont have to worry about a summer ball.
remove ur passwrds!
cos im lazy and about to leave (just did my bowtie up -- yes i can actualy do them!!) here is my running config, im sure you can see where the differences are and edit.
Current configuration : 4579 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname andrew
logging queue-limit 100
no logging buffered
no logging console
enable secret 5 XXXXXXXXXXXXXXX
username andrew password 7 XXXXXXX
ip subnet-zero
ip domain name boxen
ip dhcp excluded-address 10.10.10.5
ip dhcp pool CLIENT
import all
lease 0 2
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
partition flash 2 10 2
interface Ethernet0
ip access-group 101 in
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
pvc 0/38
hold-queue 224 in
interface Dialer1
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname buzzons@plusdsl.net
ppp chap password 7 XXXXXXXXXX
ppp pap sent-username buzzons@plusdsl.net password 7 XXXXXXXXX
hold-queue 224 in
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
transport input ssh
end
this is for an 837, so there is no wireless setup
re
Many thanks for your help , all working well
Cheers Steve
