problem port forwarding with speedtouch 530
Hi
Hope someone can help.
I am using a speedtouch 530 and want to use port forwarding to stream with shoutcast.I have got the NAT settings as follows.
NR = 1
Type = STAT
inside address =10.0.0.0:8000
outside address =212.159.59.97:8000
Prot =TCP
State =Listen
the shoutcast log looks like this.I think by the look of the last line of the log that the port is not forwarding correctly.So can any one see where I may have gone wrong with the NAPT settings or is it something else? hope you can help! Smiley
** SHOUTcast Distributed Network Audio Server
** Copyright (C) 1998-2004 Nullsoft, Inc. All Rights Reserved.
** Use "sc_serv filename.ini" to specify an ini file.
Event log:
<11/28/04@11:08:09> [SHOUTcast] DNAS/win32 v1.9.4 (Mar 17 2004) starting up...
<11/28/04@11:08:09> [main] loaded config from C:\Program Files\SHOUTcast\sc_serv.ini
<11/28/04@11:08:09> [main] initializing (usermax:2 portbase:8000)...
<11/28/04@11:08:09> [main] No ban file found (sc_serv.ban)
<11/28/04@11:08:09> [main] No rip file found (sc_serv.rip)
<11/28/04@11:08:09> [main] opening source socket
<11/28/04@11:08:09> [main] source thread starting
<11/28/04@11:08:09> [main] opening client socket
<11/28/04@11:08:09> [source] listening for connection on port 8001
<11/28/04@11:08:09> [main] Client Stream thread [0] starting
<11/28/04@11:08:09> [main] client main thread starting
<11/28/04@11:08:17> [source] connected from 127.0.0.1
<11/28/04@11:08:18> [source] icy-name:keith ; icy-genre:Various
<11/28/04@11:08:18> [source] icy-pub:0 ; icy-br:64 ; icy-url:http://www.shoutcast.com
<11/28/04@11:08:18> [source] icy-irc:#audiorealm ; icy-icq:NA ; icy-aim:NA
