printers won't print.
vic_newey
I finally got around to installing XP SP2 & everything is fine except my printers now refuse to print.
I have Epsom CX5200 & Samsung ML- 4500 Laser.
Drivers are installed properly, the print preview etc. all works o.k but when I press 'print' it displays -document failed to print. error.
No update drivers appear to be available, the Epsom ( 18 months old ) is not even mentioned on their website anymore.
I noted a common error when looking on the various forums etc. that each time the printer is turned on it says in a bubble , ''new hardware found - installed -ready for use etc. Mine does this also.
I
There should be no problem with your Epson printer and XP SP2. We have installed several with no issues.
Current Driver here http://esupport.epson-europe.com/GettingStarted.aspx?lng=en-GB&data=3F1C5E01CCD11E376E07AFF43CC194E2...
With regards the ML 4500, whilst a great printer, it has always been problematic with XP SP1 never mind SP2. There used to be a workaround for installation issues where by you installed the ML4600 Driver along side the correct one and that resolved that problem.
Havent worked with the ML 4500 for a couple of years.
Regards
Mark
vic_newey
Many thanks for that,
just downloaded , installed & working, can't understand why I could not find this on Epson site yesterday. I still think I will get the new hardware found problem tho & it adds another printer, its just done it now with a restart ! so I now have Epson CX5200 (2) & next time it will be (3) I guess I just keep deleting them.
I had the Samsung working with SP1 without problems strangely enough.
Anyway ,thanks again for your help
At the risk of sounding patronising, you arent trying to install the printer with the USB cable attached?
If yes, uninstall and re-install, only connecting the cable when prompted by the wizard.
Apologies if if this is not what you are doing.
Regards
Mark
vic_newey
Epson working o.k. did you mean the samsung ? its parallel port not usb
It was the Epson I was referring to. If its working fine then happy days.
Glad you got it sorted.
Best regards
Mark
