port-forwarding problems
I have a mac and i am connected to plusnet via an X-station wireless router. I am trying to use port 3031 (used by apple remote events) so i can access a part of my mac remotely. To do this, I set up port forwarding on my router by setting public port start and end to "3031" and private port to "3031". I also set host address to the internal IP (10.0.0.3) of the computer i am trying to access (I wasn't sure if this was the correct setting). After no joy, I ran port scan on port 3031, ip address as my external ip address 187.xxx.xx.xxx - it came up with nothing. I am yet to try accessing from another place (currently I am attempting it on the same network diffrent computer but obviously using the external IP) - would this make a difference? Any other ideas why it is not working? Any help appreciated, thanks.
MysteryFCM
First thing I would try would be from outside of the network as some routers do not support loopback (no idea about yours as I have never used a MAC, let alone the X-station router)
OK, I figured it might be that, havent had a chance to try it yet. Thanks for your help will post again if it still doesnt work..
MysteryFCM
No problem Wink
My router manufacturer, ADSLnation, said that this was the case and I had to access it from outside my network. However, I tried this today, didnt work. Any other ideas?
MysteryFCM
Can you get anything from the port from outside of the network? (if not, ensure you don't have anything blocking it).
