pc screen
pc screen
hey if i have a pc with everything but the screen and i have a laptop is there anyway of useing the laptop screen if so which wire must i get Huh
pc screen
does any1 knowHuh hellooHuhplease help meHuhHuh
michaelscott
pc screen
could you please excersie a bit of patientce on these forums, please?
I think this is probably possible but it would mean taking your laptop to bits because AFAIK, there is no cable that you can buy to do it as the laptop will not have any VGAinput.
pc screen
In short, no, you cannot use the laptop display..
If the graphics card of the PC had TV out, you could use an old TV.
Looking at the other posts you have made on this forum, I think you are delveing into something you have limited knowledge about and is liable to cause grief.
