outlook 2003
morgan2476
outlook 2003
Hi I have just re-installed windows on a new hard drive and everything is ok but for 2 things in outlook.
1 the text of the emails is plain
2 everytime i shut down the program i get the following message "The macros in this project have been disabled"
would appreciate some help
grimme
outlook 2003
A couple of ideas related to your question, not guaranteed to be "THE" answer, but it might point you in the right direction!
Option 1 - only thing I can think of here is the Tools, Options, Mail Format setting is set to Plain TextHuh?
Oprion 2 is usually related to a Very High Macro setting in Office - look in Tools, Macros, Security and see what the security level is, reduce it by one level at a time to see if it goes away.
HTH
Njal
outlook 2003
Are you using Word as your e-mail editor? If so this might be your answer:
http://forums.channelweb.co.uk/thread.jspa?forumID=10&threadID=71953
Regards,
Neil
morgan2476
outlook 2003
Yep that is that sorted. I checked my email at 10.30pm on monday the 6th and i received an email on Tue 07/11/2006 04:52 what has caused this
