no access to folder
no access to folder
now i have 2 windows xp installations
my previous username was naeem
i had a folder called naeem also in document and settings as a user
but access is denied to that folder
how can i access it
and i cant log onto username from the previous windows xp
any help appreciated
no access to folder
Are we talking about XP Home or Pro?
Are you signed on as a limited user, but trying to access folders secured by a user (with computer admin authority)
To access all your folders you need to sign on as administrator account.
no access to folder
Yeah, those are the standard permissions.
Ask an administrator to change your account type to one with Admin rights.
If the admin doesn't want to give you access to everything, they grant you permission to a certain folder or file using the inbuilt windows permission settings.
no access to folder
yh thanks guys
ive sorted it out,
no access to folder
You mean WE sorted it out. Wink
no access to folder
yes of course sorry mate!
could'nt have done it without you,
cheers
