network cards with widows ME
I am trying to install a network card to enable me to share access to the internet via my internal adsl modem with an X-box.
I am running ME and when I install the card and run the software and then re-boot and try to connect to the internet, the modem control panel says connection established but when I doubleclic internet explorer it says cannot find server.
ICS is enabled, and checking the settings in connections before and after nothing seems to have changed.
Also after installation my outlook express will not connect.
Has anyone any ideas please or will i have to buy a stand alone adsl modem and router combined.
Many thanks
JCNPLC.
1 REPLY
goto ie..
tools ->options->connections -> Lan settings
and make sure no proxy is ticked
