netgear dg384uk help
i have just got this modem thanks to all for there help in getting this modem.
q1
this modem has a built in firewall will my mcafee firewall work with this or its two seprate things mcafee 2006 internet security............................... Cry
q2...........
will this seup on the ethernet ok got one in the back of the pc i think using a bt voyager 105 should i uninstall the drivers befor installing the netgear because that is usb for my old modem ..................................... Shockedops:
1 REPLY
1 - The built in firewall runs totally seperate of any other firewall you run on your computer, so any software you have would be like a backup just incase the netgear misses anything but to date I have never felt like its ever let anything through it shouldn't have.
2 - The netgear requires no drivers as it is ethernet based, it is entirely up to yourself wether you want to remove the Voyager drivers, you may want to tosave space on your computer and also it will cut down on what is loading on startup.
