msft ie7 beta 2
msft ie7 beta 2
Hi the above is now freeley open on the msoft web site,look in vista then follow the signs,if anyone has found this and is useing it anyHuh?? why my favorites will not open,they did work.but for some reason they just sit there.if i click on anything i get a red cross come up which feels bad.I am sure its a set up thing but can not put my finger on itHuhHuhHuhHuhanyone :roll:
msft ie7 beta 2
i used it during the beta but it messed up programs like flight sim and msn does it still?
you can download it at http://www.microsoft.com/windows/ie/ie7/default.mspx
and it does have windows vaildation on it!
msft ie7 beta 2
I've just pulled it down and some how suspect it will remain for windows updates only...
Loading the same page in FF and IE7 (the forums index page) IE used 60+ MB, FF 29MB...
Not a good start (especially with the all the complaints about FF's memory foot print to come up with an even worse one with less features takes a special kind of programmer Wink )
