mp3 files
mp3 files
I was wondering if it was possible to extract the voices from mp3 files to make them instrumental. Does anyome know any software that could do this to an mp3 file?
: :roll: :roll: :roll: :roll:
keithcalder
mp3 files
Have you tried Cooledit Pro, I'm not sure if it does the particular task you mention, but believe it may be capable. In any case its worth a try.
mp3 files
Goldwave
You can use either the app's integral Voice Reduction effects or with a DirectX plug-in such as Creative's Karaoke Filter.
