monitior gives persistant high pitched squeal
My monitor gives out a high pitched squeal when the page on display is mainly white, such as these forums. If I go to a coloured page the squeal dissapears.
The squeal is almost as bad as my tinitus.
Any ideas. Changing resoloution dosn't really make much of a difference.
A
have you changed the Hertz in the monitor settings this should cure it?
Monitor settings in windows or on the monitor. The monitor dose not have the option to change hertz.
I've changed it in xp and will see what happens.
A
zebo-the-fat
Could be a mouse in the monitor!
I had a similar problem with a TV, (intermittant high pitched noise) the repair man sprayed one of the transformers with some kind of varnish and the problem has not returned yet (over 10 years ago!) I think the transformer was vibrating slightly and the varnish just held it in place.
The varnish was probably to insulate the high tension side of the transformer.
*EDIT*
I just remembered, a tv we used to have, had a large capicitor that was making a high pitched whistle for a while.
It eventualy went pop and set on fire! :shock:
The noise you are hearing is at the same frequency as the noise that only under 24 yr olds can hear! Its the one thats been developed into a mobile phone ringtone that teachers can't hear and now a dance track! Genius Cheesy
