modems HELP
modems HELP
Can anyone tell me. I have a BT Voyager 100 and a Zoom 5510 ADSL Modem. Which is the best to use?
"Will it make a difference?"
[Moderator's note by Mark (pcsni): Post changed from all caps as it is considered as shouting and rude.]
Denzil
modems HELP
In theory they should both work equally well. Pick one and try it. If it works then keep the other as a spare, if it doesn't work try the other Cool
Incidentally throughout the internet typing in capital letters is generally regarded as shouting and a bit rude. I am sure this isn't what you meant, just remember for next time Wink
arlehaven
modems HELP
Both should work equally well as previously stated however, I believe that Plusnet will offer support for the BT voyager products whereas I don't think they will for the Zoom. Just incase you had connection problems in the future and required support you might be better using the BT Voyager 100.
