modem the best buy
modem the best buy
got a bt voyager 105 need a better modem anyone know witch is best a do not want to go usb any more
i have only 1 computer would a router be any good i have £50.00 to speed
the 105 modem will be no good for the 8mb soon Huh
modem the best buy
I think the 105 is fine for 8mb but a router would give much better line stats which may increase your speed.
I'd suggest you get one of these:
http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=898
A little over your budget but its wireless and capable of ADSL2 for the future. I use the same one and its a dream to use, easy installation etc and firmware upgrades are pretty simple too.
Although this one more suits your needs and is much cheaper:
(removed link) Check the message below - as stated much better router Wink
modem the best buy
If you buy a Netgear get the DG834UK it is a much better router.
>>link<<
The DG632 had a lot of problems and software updates to get it reliable and also does not give line stats.
modem the best buy
thank i will have a look :lol:
Fixes: 57
modem the best buy
I have been following a similar track for a friend who is going broadband and my present favourite is the Speedtouch 516 or 536 which are based on a broadcom 6348 which is apparently one of the better chipsets.
Have a look at this thread
