minimizing O.E
minimizing O.E
does anyone know how to minimize outlook express to the system tray so i can leave it open all the time to check periodically for mail ?
yes i know its being lazy.
please dont say use incredimail ive tried that and do not want extra programs installed just for email outllook does the job fine but i would like it out the way in the tray.
many thanks
mark
minimizing O.E
Outlook and Outlook express do not have this feature, so is not possible by default.
However, there are programs you can get that will sit in the tray, and allow you to sellect and open program, assign it an icon, then then send it to the tray (it should save the details, so you pick it from a list the next time).
However, I don't know the names or the locations of such apps.
Try download.com and tucows.com
minimizing O.E
A good program for what you want to do is "Mail Washer" it will sit in the system tray and check for mail every 10 minutes by default. but you can set this for whatever time you like.
Mailwasher also has some other benfits.
The main one being that you can see your mail before you download it and delete any suspicious ones before they get to your PC.
Well worth getting.
minimizing O.E
thanks guy's ill try mail washer
mark
