microsoft word
microsoft word
I have had a go at opening word and other bits that come with it but it wil not work and al i get is wkswp.exe entry point not found.
and somethign about dynamic link library
I was usin the 207 beta but that run out and had to uninstall
any ideas folks on how to if i have to uninstall and reinstall i have a works 8 disk some place
holdtight
microsoft word
Hi
After googling your problem its been suggested to see if you can find the
WkWbl.dll file on the Works CD and copy it into: C:\Program Files\Microsoft Works\
and replace the existing copy which may have become corrupt
Or if that doesnt work deleting the works folder after uninstallation then reinstalling
the program seems to have fixed the problem
hope this helps and you can have a read Here and Here
Bill.
word
Thank you for the advice.
I have done the uninstall and have reinstalled and it seems to be working fine, once again thank you for your help
holdtight
microsoft word
No problem glad you got it sorted !
Bill.
