messaging on network
hi all
has xp got a messaging service so i can message my son upstairs instead of screaming up to him.
if not does anyone know a program that would do this?
i just want a messaging program to use on our network thats it not an online one
cheers
mark
Try net send.
Open a dos window (run > cmd)
And type net send [pcname] [message]
eg:
net send upstairspc turn your bloomin music down!!!
HTH
cheers wiggy but can't get it to workHuhHuhHuh
Both PCs running XP?
IP address should also work.
eg:
net send 192.168.0.2 test message
what error did net send throw back?
If both machines are XP/NT then it sounds like the problem is that the Messenger service isn't enabled. To enable this :
    1) Click "Start" > "Control Panel"
    2) Double click "Administrative Tools"
    3) Double click "Services"
    4) In the window that opens, scroll down the list until you find "Messenger"
    5) Click "Start the service".
This will set the service to always start when the machine is turned on.
By turning this on, you may begin to receive "spam" messages which appear in popups. Just making sure you're aware of a possible consequence Smiley
This has been enabled on my PC. I've never had spam. Are there any what other possible consiquences?
Not that I know of, I've only ever received 2 spam messages from it. I think if you have a router, they won't come through.
Re: messaging on network
I dont think he wants one on the internet. It sound s like hes after something like winpopup that is on win 98
Just tried that by the way but it wont run on XP Cry
net send used to work fine between my two XP machines on my LAN. I use it all the time on the LAN at work as well.
i've found that sending a message from Winpopup to an XP machine displays as a Messenger service popup. Not sure if it works the other way round though (winpopup loaded on the 98 pc and net sends from the XP machine) :?
thanks for the help fella's
got net send to work now
it does the job a treat i can now slag him off upstairs without moving
many thanks
mark
