memory crucial v kingston
hiya peeps
was up to now buying crucial memory chips
but started getting a few faulty ones have found out i
can get kingston memory a little cheaper
wondered on you thoughts out there
regards
Rob :?
I thought Crucial gave a lifetime warranty - so you should be able to get them replaced if you are the 'initial customer'.
I always buy Crucial (bought about..10 sticks so far) and have never had any problems. As pacaya said, all sticks are covered by a life-time warranty, so you shouldn't have problems there.
I've also heard that Crucial are supposed to be very good... so I'd say stick with them, unless you have a really good reason not to.
Thomas
