macro problem
morgan2476
macro problem
Every time i start outlook i get a message to either enable or disable macros. How do i get rid of the message? Is it safe. Is it safe to put the security level to low considering the fact that Micrsoft does not reccomend it?
1 REPLY
macro problem
What is the macro? This is normally caused by something you installed like Adobe pdf maker. First check what the macro is it should be asking for only one macro to run not all. Running all macros is very dogy
