lost xp oem key help
hi all a built my computer myself then i bought a prober oem copy of windows xp home the only thing is i have lost my key and cant wipe my computer
cos i have errors on my drive i dont think microsoft can help me some one said i could email them the id on my computer and microsoft would send my my key back but i cant find the email link Sad
Gareth
A good place to start would be the link below.
Tip when you get the code back use a CD writer pen and write it on the CD. I do this with all my CDs that need a code. then if you have the CD you have the code as well Wink
http://www.microsoft.com/uk/contactus/
Also Microsoft Contact Centre: 0870 60 10 100
If you have a OEM copy of XP, you should be able to use internet activation.
Alternativly, you should be able to phone them, so long as it has been over 2 months after your last activation (too expesnsive to hold the information in a active DB longer than this).
go to my web site
http://www.mwright.plus.com/xp.htm
there is a util on this page that will read the key from xp simple as that
Hi Gareth check your PM if your still having probz...
