iChat AV beta problems
I am running a Titanium G4 and I've just downloaded the new Beta iChat but no one can see me as online. I have a Solwise SAR 110 ADSL Router. I can't chat using video or audio because even thought I'm online all my friends see me as offline. Really annoying. I looked on the apple site and got this as a reference:
http://docs.info.apple.com/article.html?artnum=93208
All alien to me. Can anyone help?
Luke.
I would suggest consulting your router manual for a reference to "port forwarding". That should do the trick Smiley
cheers, i'll have a look.
I'm still clueless.
Video iChat and Solwise 130
hello everyone,
I am also trying to enable Video iChat using Solwise 130 router.
I can chat with other AIM /iChat,but can not mange to start a video chat.
From the Error message i get in i chat (Connexion Doctor):
2004-12-05 18:58:22 +0000: XXXX did not respond.
Tried to send UDP SIP "invite" to the following IP addresses and ports:
AA.AA.AAA.AAA:49838, XXX.XXX.X.X:5060, XXX.XXX.X.X:5060
It seems that I have to add some incoming / outgoing rules onto my router to enable communication via the port 5060.
as XXX.XXX.X.X my current static IP.
I ll keep you updated, as long as I am getting closer to a solution.
Stephane
Hi
This is where I found out how to set up iChat and hope it helps
Ian & Linda Jordan
Sorry folks I missed the same link in the original post, but not wishing to sound depressing I did'nt succeed with the Solwise 130 that Plusnet sent me, and ended up getting another modem/router:although i am sure there must be someway to do it with a Solwise router I was never able to find it :-(
Ian & Linda Jordan
it works with a solwise 130
Tonight I made my first video conference with a friend back in France, using ichat AV, iSight and a solwise 130 router .
I did not touch the network config of my G4laptop. nor did I play with the listing of port available on the router.
I assume that it did not work before, as my contact was then connected on a highly secured network (where all requiered port where not available).
I ll do another attempt tomorrow evening.
Stephane
PS: thank you sunhouse for the link.
