i can't uncheck my folders from read only....
..., for some reason all my folders have set themself to read only and any attempt i make either clicking on properties and unchecking it there or even using cmd prompt fails to work......i am completely out of ideas ?
1 REPLY
I assume you are on XP?
Are you logging in with full admin permissions? if not then the system wont let you make changes.
