how to get winicfg for windows xp
hiya all
can`t find the winicfg command on xp
any one know if its there! or can i get from somewhere else Shockedops:
I think you mean "winipcfg"?
Btw, I've moved your post, as it's not specifically about ADSL.
Thomas
And if you do mean winipcfg - that doesn't exist in XP. the 'ipconfig' command is the XP version of winipcfg.
...and needs to be run from the command line.
Thomas
Many thanks
Many thaanks
sorry keyboard skills no good on spelling!!!!
you need ipconfig /all to do any good
