have i been hijacked
started using ghostsurf recently now my norton security shows there are loads of emails being sent from my pc = but nothing being sent from outlook email sent items =does this mean i have a worm or worse ? is sombody using my server to send spam or worse ?
You would expect anything sending emails to be picked up by Norton have you done a full scan? Does the firewall show any programes that allowed to send outbound which you dont reconise?
goto http://www.wfshome.com/software.htm> http://www.wfshome.com/software.htm
and get the free whats transferring run it and it will show everything going out so you should be able to spot whats going on and were its coming from.
norton is telling me that my pc is sending emails (lots of them) but nothing showing in my sent emails log - i have scanned with spysweeper and norton but nothing is being found.. if i stop/exit ghost surf it stops the emails being sent..
only when ghostsurf is installed does the emails send.. 10/15 at a time?
Legit or copy of Ghostsurf? If Copy I'd say its been re-engineered, the fact that if you turn it Off the problems stops.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
no all legit - all purchased from tenebril - it worked fine for approx 3 months
then emails by the score being sent but nothing in the outlook sent box.
i will ask tenebril for advice today- regards ron
tenebril have a patch for the problem - appears the cybercrooks are winning the battle- installed patch all cured - for now !!
