hard disk problem
hard disk problem
i have an external hard drive
its a internal hard drive inside an icy box
having a few problems with the connection
hard drive is maxtor 200gb
hard drive sumtimes appears as laxtnr and other funny names
thts 1 problem
other 1 is when i try accessing it , it says format it, then one day it started to work, and now again it says format it
well different things happen on diferent computers
any help would be appreciated
hard disk problem
What OS are you running, is it USB or Firewire? is the jumper set correctly?
hard disk problem
win xp
its usb
the jumper setting is fine
i mean the hard disk does work fine sometimes
i think its the ide cable it plugs in 1 side more than the other
Rich
hard disk problem
Seen this a few years ago with a cheap caddy - the hard disk inside was over-heating.
hard disk problem
nah i dont think its overheating
but does anyone think there could be any other problem
maybe a partitioning problem?
holdtight
hard disk problem
Ive seen it recommended that when you first connect an external drive to a system that you format it straight away
Cant remember where or when or whether it makes a difference
hard disk problem
yh did format it first thing
