freeview dongles
freeview dongles
Hi,can anyone please tell me how good these work.Quality of picture and soforth.Thank you.
freeview dongles
I have been thinking about one of those. As the system is digital, although analogue transmission, the signal has to be good or you get nothing. But if you do have a good enough signal then all should be well. I am very sceptical though about getting a suitable signal with such a small antenna. So the only way I can find out is to shell out the £30.
bewick
freeview dongles
I'm using a Presto "Sky" PVR dongle.
attached to a loft aerial via a possibly dodgy co-ax cable.
By and large it's excellent. Picture great and and only "stutters" now and then.
The teletext doesn't work though and not all all available programs appear - Sky News and Five Live have recently disappeared from the list for eg..
I did have the EPG working at one point but that now crashes the program. The few problems I have though I'm putting down to the quality of my aerial. The supplied mini-aerial is of no use indoors!
freeview dongles
Which one did you find at that price, please?
freeview dongles
Have a look at SVP
http://svp.co.uk/products-list.php?cid=179
I have used these people and find them OK
bewick
freeview dongles
and aria
www.aria.co.uk/ProductInfoComm.asp?ID=20886
This is the one I have which I described as Presto - which it is
freeview dongles
Thanks for the links. Yes, have used SVP before, and often see "must have" bargains there!
Just saw the requirements... one mentions 1 Gb free disk space... seems a lot (but nowadays 160 GB drives are getting to be the norm, so maybe just me being an old fuddy duddy!)
freeview dongles
One other thing to bear in mind is that generally these dongles do less work themselves and more (sometimes a lot) of processing is done by the PC itself. For example if you record a programme, the encoding (mpeg2 or whatever) can be quite resource-intensive.
OTOH many of the cards and bigger USB-connected boxes have hardware encoders on-board, so you can use your CPU cycles for something else, should you want/need to.
